It is currently Tue Sep 16, 2025 9:15 pm
 Post subject: A20 Wakeboarding setup
PostPosted: Thu May 22, 2014 1:11 pm
This one's for all the A20 owners; What are you guy's using for rope length/ speed/ ballast set when wakeboarding?
I know the smaller boat size can make for some funky configurations, and I'm thinking of redialing my wake this year, so just looking for ideas
Last year’s set up was;
65-70' rope length @ 21-23mph with all hard tanks full, 600lbs PNP in both lockers, 950 arrow PNP up front, 400lbs bag on the seat in the bow and wedge down.
My issue was i felt the wake was a little wide so I'm not sure if I should shorten the rope, speed up or lighten the weight.
-Pat
 Post subject: Re: A20 Wakeboarding setup
PostPosted: Thu May 22, 2014 1:19 pm
I'm running simlar ballast setup in my A20. I ride 60ft @ 22mph. It's definitely a wide wake. For reference, I feel that it is equivalent to running 65ft @ 22mph behind an A24 (which I ride behind frequently as well).
PostPosted: Thu May 22, 2014 5:47 pm
Yep I'm close to the same weight setup as well. Wake is awesome for a 20' boat! We ride 70' rope at 23.4 mph. Not sure if that's accurate I've never had my speedo calibrated. I've tried riding at 75' and its a long ways across the wakes
PostPosted: Thu May 22, 2014 6:12 pm
We are basically the exact same setup and rope length as you guys, factory +750p&p plus nose bag + wedge and 65ft at 22mph
2013 A20
PostPosted: Thu May 22, 2014 7:08 pm
Same setup basically for me too: hard tanks, rear 750s filled about 3/4, front arrow bag under seats, 370# tube sac on the seat in the bow, no wedge. 60ft, little over 21mph.
