It is currently Fri Sep 18, 2026 3:11 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2, 3  Next
 Post subject: 2014 PnP rear drain install for Sumo 750 & 900
PostPosted: Tue May 06, 2014 2:41 pm
Just wanted to show how I did my rear drain so my 900's can be as far back as possible and to minimize any chance of the fitting popping off with the factory routing. I just shortened the factory hose by at least 2/3's and then added 2 elbows. To notch the triangle floor panel I just used a Dremel.
 Post subject: Re: 2014 PnP rear drain install for Sumo 750 & 900
PostPosted: Tue May 06, 2014 2:48 pm
I just plugged the back and ran mine through the front drain. Then you can put it as far back as possible.
PostPosted: Tue May 06, 2014 2:52 pm
I wanted to take advantage of 2 drain ports in the sack and the 2 drains in the hard tank. Hated the slow gravity feed with only the one drain port in the hard tank in my 2011
PostPosted: Tue May 06, 2014 7:27 pm
Done mine very similar. With just one drain was to slow.
2013 A22
PostPosted: Mon Sep 15, 2014 12:17 am
Very nice. Thanks for the pics. Great idea!
PJ
2014 Axis A22
PostPosted: Thu Jul 09, 2015 2:13 pm
how did you connect the two elbows together? one of these? http://www.wakemakers.com/fly-high-pro- ... ouble.html
PostPosted: Thu Jul 09, 2015 5:18 pm
No sir, I just used marine silicon and connected them together directly. I figured I'll never need to take the two elbows a part anyways so cut the chances of any leaks and used the silicon. In the pic you can see the red ring of the first elbow connected to the drain tube poking up out of the notch cut-out and the top bow is simply siliconed into it.
PostPosted: Thu Jul 09, 2015 10:07 pm
Thanks AJ this thread should be "sticky" as it looks like every axis owner with PNP will need to do it at some point.
PostPosted: Fri Jul 10, 2015 12:36 am
Just did this last week. Our fittings kept popping off on the back drain. Did exactly what AJ did and it worked perfectly tonight. My dealer wants me to show their shop guys what I did. So they can start recommending and then changing other axis owners boats. Apparently they have been having this problem for awhile. Umm axis/Malibu are you there??? :D
PostPosted: Fri Jul 10, 2015 11:17 am
Is this fix specifically because yall are using sumo bags? I have the fly-high 600s (I think) and I'm considering upgrading to something larger because I can't seem to get a long enough surf wave and good push with my current set up. Just wondering if this is something I will end needing to do if I upgrade. Haven't had an issue with my drains popping off of the fly-highs yet or at least that I know of...
I imagine the entire rear storage area fills with water when they come loose?
Users browsing this forum: Majestic-12 [Bot] and 30 guests
