It is currently Wed Nov 05, 2025 3:40 am
[ 7 posts ] |
bryce2320
Post subject: First 10 hours on boat, so what needs changed? Posted: Thu May 01, 2014 8:05 pm |
I've got my first 10 hours on my A22. I don't want to drag my boat an hour to the dealer and have it sit outside til the weekend, and the motor is easy to work on so it's hard to pay someone else to do it. What all do I need to change after the first 10 hours, and when is everything need changed again? 50 more hours? End of season? I'm thinking about buying a vac pump to pull the oils out. What's the best kind to get?
The engine oil, and oil filter? Impeller? Tranny and v drive oils? Is that all or is that overkill? And does anyone have part numbers for everything, or should it all be in the manual? Will I be good to wait til end of season to change everything? My dealer said to change everything after first 10 hours. Thanks in advance.
DatTexasBoy
Post subject: Re: First 10 hours on boat, so what needs changed? Posted: Thu May 01, 2014 8:24 pm |
Joined: Thu Dec 15, 2011 7:57 am Posts: 779 Location: East Texas
All that except impeller at 25hrs
_________________ 2010&2014 A22 2012&2015 MB 2016 Supra SA400
AJWest
Post subject: Re: First 10 hours on boat, so what needs changed? Posted: Fri May 02, 2014 10:27 am |
I believe they will also check the motor mounts and prop shaft alignment
x_40oz
Post subject: Re: First 10 hours on boat, so what needs changed? Posted: Fri May 02, 2014 12:57 pm |
follow up qustion is when do you do the impeller?
My boat now has 52hr
mcmiller
Post subject: Re: First 10 hours on boat, so what needs changed? Posted: Fri May 02, 2014 3:46 pm |
Joined: Sat Aug 17, 2013 1:17 pm Posts: 162 Location: Cincinnati
I do the impeller once a year and I have never had one fail.
Alcork
Post subject: Re: First 10 hours on boat, so what needs changed? Posted: Fri May 02, 2014 9:27 pm |
Do you have a link for buy impeller ? Thks
nastya20
Post subject: Re: First 10 hours on boat, so what needs changed? Posted: Sun May 04, 2014 8:38 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 53 guests |
