It is currently Tue Nov 04, 2025 12:43 pm
 Post subject: Front mushroom sac draining it's self
PostPosted: Mon Apr 28, 2014 2:09 pm
My front bag was draining it's self. Come to find out it was a bad check valve. [attachment=-1]uploadfromtaptalk1398715716292.jpg[/attachment][attachment=-1]uploadfromtaptalk1398715735604.jpg[/attachment]
 Post subject: Re: Front mushroom sac draining it's self
PostPosted: Mon Apr 28, 2014 6:56 pm
Check valve on the drain? Mine drains itself too. I was gonna stick a manual cut off on it. Where is the check valve? I don't know what I'm looking at in your pics.
store.kultureva.com
Poor Gate Equiped
PostPosted: Tue Apr 29, 2014 3:53 am
Its that grey thing you see. Yours will be smaller but should have one on the top side close to the cabin. That is the fill line. The one I had before would not hold.
PostPosted: Wed Apr 30, 2014 10:19 am
so to clarify its draining threw the fill line?
PostPosted: Wed Apr 30, 2014 10:47 am
Yes it was.
PostPosted: Wed Apr 30, 2014 12:04 pm
My fill line is up high. Mine drains through my drain line. Gonna get ball valve.
store.kultureva.com
Poor Gate Equiped
PostPosted: Wed Apr 30, 2014 12:59 pm
I have mine drain into main hard tank so I always fill and then close the ball valve right by driver seat
PostPosted: Wed Apr 30, 2014 1:43 pm
Did you bypass the other drain pump?
PostPosted: Thu May 08, 2014 9:50 am
This in fact did fix my problem. The old check valve on the fill line was garbage.
