It is currently Wed Jul 22, 2026 9:25 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Acme 2079
PostPosted: Thu Apr 24, 2014 6:25 am
Looking for more bottom end power. I run about 4100lbs without wedge and this does not county gear and people. 2313 struggles. I have a couple other guys I know running same weight and they can get on plane with 2315. Won't hurt to try 2079
PostPosted: Thu Apr 24, 2014 6:52 am
What is your weight configuration while running the 2313? I want to run about the same configuration if you have it dialed in.
PostPosted: Thu Apr 24, 2014 7:00 am
UPFRONT
Mushroom full as I can get it (800ish)
Sumo 650 triangle FULL
CABIN
300lbs lead
REAR
Sumo 600's
ALL STOCK TANKS FULL (no wedge)
PostPosted: Thu Apr 24, 2014 8:35 am
DatTexasBoy wrote:
UPFRONT
CABIN
300lbs lead
REAR
Sumo 600's
Sounds about like what I plan to run. I picked up a Sumo 650 Triangle last weekend for $117 out the door, taxes included. I felt like I stole it.
Anyways, I plan to run:
900lb x 2 rear full
650lbs Arrow sac (I still don't think it provides the 950lbs being under the bow seats)
650lbs Sumo Triangle
900lbs Full Stock ballast
and 3 or 4 people in the boat.
No wedge. 2315 prop.
I should be able to achieve the same wake as you. I may have to drop a little in the rear. Hopefully I can get some gopro pics on Saturday when I go out.
PostPosted: Thu Apr 24, 2014 9:00 am
Pictures are so overrated. Too easily manipulated. Fun to see but can't really put to much credibility into them. I'll take some too and were can see.
Btw you did steal that bow sac. That's a great price.
PostPosted: Thu Apr 24, 2014 10:34 am
The front arrow bag under the seats is only able to fill to about 475 I think .... per axis wake website
PostPosted: Thu Apr 24, 2014 10:41 am
It fills way more than that. I'm betting 7-800
If that it's true it sucks
PostPosted: Thu Apr 24, 2014 11:01 am
there is no way to prove it ..... well there is but it would take a lot of effort ..... but im sure someone on here remembers the video with the owner guy explaining the ballast weight and indicated that the bag under the seat would not fill to max capacity and the # he gave was in the 400's. 800 is way to close to max capacity I don't think its getting that much under the seat. I have my arrow on top of the seat and I have filled it full and that thing expands like no other but it never got close to that under the seat. it might hit the 500's but I don't think 800 ..... but who knows id like to see someone fill it under seat and then drain it into a diff bag and weight it
PostPosted: Thu Apr 24, 2014 11:23 am
I went thread digging and found a few that claimed 650's under the seat so I was low and you are high I believe one member ferrel I think actually tested it and said the 650's #
PostPosted: Thu Apr 24, 2014 11:28 am
That is why I used 650lbs also. I read the same thread a while ago.
Users browsing this forum: No registered users and 112 guests
