It is currently Sun Sep 20, 2026 2:24 am
 Post subject: T22 Bow Ballast Bag
PostPosted: Fri Mar 21, 2014 11:13 am
Does anyone know what manufacturer makes the under seat bow ballast bags for the new T22?
2014 T22
 Post subject: Re: T22 Bow Ballast Bag
PostPosted: Fri Mar 21, 2014 1:52 pm
Just got off the phone with BFI.. Here is the BFI bag:
http://www.boardstop.com/product_info.p ... ts_id=6931
I also have the plug and play listed here:
http://www.boardstop.com/product_info.p ... ts_id=6933
http://www.boardstop.com/product_info.p ... ts_id=6934
I assume that they are 4 hole bags just like the other 2013-14 Axis boats.
PostPosted: Fri Mar 21, 2014 2:23 pm
Thank you for the information. I looked at the Boardstop website and didn't think I saw anything on there.
Our boat is on order and it will have the pnp set up. Do you know if there is anything else we will need other than the ballast bags.
2014 T22
PostPosted: Fri Mar 21, 2014 2:41 pm
I just got off the phone with Malibu in TN. They said it would only need a 3 hole but would recommend getting a 4 hole so that the 4th hole could be used as a vent.
2014 T22
PostPosted: Fri Mar 21, 2014 3:00 pm
We just added them today since you asked about them.
PostPosted: Fri Mar 21, 2014 6:50 pm
StraitLine also makes this Bow Bag that we just installed in a customers T22 and it fit without any issues. Also has 1" ports and makes full use of the HiFlo lines with the Axis PnP.
PostPosted: Wed Apr 09, 2014 9:47 pm
Isn't the pic on the boardstop site the A24 sac? I would think the T22 bow sac would be triangular. Also, what is the listed/actual weight of the sac in the T22 bow?
2012 Axis A20
PostPosted: Thu Apr 10, 2014 9:15 am
You guys are correct.. I do not have a current picture of the T22 sac. I believe that sac is more like a triangle. I have one on order so I can get a picture of it.
PostPosted: Tue Apr 22, 2014 12:21 am
updated the picture.. it will be similar to the regular triangle sac. I have already sold a number of them from flyhigh.
http://www.boardstop.com/advanced_searc ... ywords=t22
