It is currently Tue Sep 16, 2025 9:30 pm
 Post subject: Ford Edge AWD 2007
PostPosted: Fri Apr 04, 2014 12:56 pm
Is it possible to pull a axis a22 with this truck, thks you
 Post subject: Re: Ford Edge AWD 2007
PostPosted: Fri Apr 04, 2014 1:37 pm
Well the tow rating for the '07 ford edge is 3500lbs. The 2014 A22 is listed at 4000lbs without trailer.
I don't have a lot of towing experience Im a new boat owner but if it were me I would not feel comfortable with that as a tow vehicle.
PostPosted: Fri Apr 04, 2014 2:35 pm
I wouldn't use an edge to pull an A20, definitely not a 22. That's just me though. It's possible, sure, but I wouldn't recommend it. How far will you be towing and how frequently?
PostPosted: Fri Apr 04, 2014 2:41 pm
There's no way I'd try an A20 either much less an A22. 4000lb boat, 1000lb trailer (approx), 40-50gal fuel, batteries, gear, cooler(s), etc and you're over 6000lbs. Then you have pull the boat up wet ramps.
PostPosted: Fri Apr 04, 2014 4:15 pm
PostPosted: Sat Apr 05, 2014 8:36 am
No. Don't even try it...
PostPosted: Sat Apr 05, 2014 4:23 pm
Ok thanks for your advise i check for a pick up
PostPosted: Sat Apr 05, 2014 5:29 pm
If it's short distance and no hills. You can chance it :)
PostPosted: Sat Apr 05, 2014 7:43 pm
The marina is situated has five minutes of my house and the slope at the marina is very soft...
PostPosted: Sat Apr 05, 2014 10:28 pm
Sounds like you'll be fine if you go slow.....
Users browsing this forum: No registered users and 66 guests
