It is currently Tue Nov 18, 2025 3:17 pm
Giesh164
Post subject: Re: Any good suggestions for cleaning the hull? Posted: Tue Feb 25, 2014 8:27 pm |
| Boater |
The acid works great. But like mentioned, make sure you don't get any of it on your rub rail or plastic. I wasn't extremely careful when I did mine and it got on spots of my rub rail. It discolored the black to white... Rookie move on my part.
alexandera
Post subject: Re: Any good suggestions for cleaning the hull? Posted: Sat Mar 01, 2014 8:29 am |
Joined: Sun Sep 16, 2012 8:55 am Posts: 375 Location: Central Texas
Amsug... if you YouTube Hula Boat Care they have demonstration videos which even suggest the polisher speeds. The 6" pads are just about the perfect size for working around our boat's curves and valleys. I think I run medium (4-6) speeds on my ROP and it works great!
It doesn't take much wax/polish for each 3x3 square.
_________________ -aha-
Axis_UK
Post subject: Re: Any good suggestions for cleaning the hull? Posted: Mon Mar 03, 2014 7:32 am |
The acid you need is Oxalic acid - You can buy it in powder form and mix it with warm water. The off the shelf product is called Y-10, but it's pretty mild.
For buffing you need a wool mop to start with. you can go finer afterwards but you likely won't need to. 3M marine polishes are the best I've used, but any abrasive quality polish will work.
_________________ http://www.Malibu-Boats.co.uk| http://www.AxisBoats.co.uk
amsugg
Post subject: Re: Any good suggestions for cleaning the hull? Posted: Thu Mar 06, 2014 3:38 pm |
Users browsing this forum: Google [Bot] and 66 guests |
