It is currently Sun Mar 01, 2026 7:32 pm
 Post subject: A20 Prop Question
PostPosted: Thu Feb 20, 2014 10:57 am
If a A20 is heavily weighted what is the best prop to go with... ? For the last two years I have been running the high altitude prop.
2015 T22
PostPosted: Thu Feb 20, 2014 11:07 am
There is a lot of information out there already but don't think it's all in one spot. Shouldn't make a difference on whether it's an A20 or 22 either, info should apply to both. Wish someone would just post all of the popular props in their order of aggressiveness (and possibly weight ranges):
ACME 1235
OJ Cinco
ACME 2315
Etc...
 Post subject: Re: A20 Prop Question
PostPosted: Thu Feb 20, 2014 11:41 am
I found these threads very helpful.
http://www.wakeboatowners.com/viewtopic ... 957d45bb18
http://www.wakeboatowners.com/viewtopic.php?f=15&t=1598
PostPosted: Thu Feb 20, 2014 12:03 pm
Acme 2079 or 2419 are beasts.
PostPosted: Thu Feb 20, 2014 12:35 pm
I've found this may not be the case. I have an A20, and when I was first starting out I read all the great info on here about how people were weighting their boats (mainly 22s though). I found that with same weight, same prop, relatively same conditions my A20 would not behave in the same manner. Other posts I've seen on the 20 seem to suggest that as well....very, very similar but you have to be a bit more careful on weight placement. LOL Also, on the wakepros site it lists the 2079 as the heavy weight prop specifically for the A20, all the others it lists the 2315. I believe it is because there is just less boat...it takes less weight to 'slam' an A20 than an A22. Also, because they are shorter, the front to back weight ratio starts to matter even more I believe.
As for props, from all of my experimenting ( a LOT) and reading you've got the most aggressive prop you need (assuming you're not having any issues getting on plane) unless you really want to slam it. If so, then you'd take the leap to the 2079 which is what I have ultimately landed on. It turned my 20 in to a tug boat that can haul just about any weight configuration I have thrown at it without issue. I did lose a lot of top speed and gas hurts a bit for normal riding, but worth it in my opinion.
If it matters, here is my weight set up:
Loaded Bag Lead Total Dist.%
Bow 675 320 995 32.7%
Mid 400 400 800 26.3%
Rear 1250 1250 41.1%
Totals 2325 720 3045 100.0%
2012 Axis A20
PostPosted: Thu Feb 20, 2014 1:55 pm
ACME 1235
OJ Cinco
ACME 2315
Etc...
You're correct that the prop suggestions won't differ TOO much, but the A20 will struggle to get on plane just a little bit more than the A22, due to it being a shorter hull. It will be marginal, but if an A22 is JUST BARELY getting on plane, then the A20 might not be able to get the edge and get down on plane.
PostPosted: Thu Feb 20, 2014 1:58 pm
Agree that you have to be more mindful of weight placement from front to back, but it's really not much more of a concern in comparison. I have also weighted both, and they are very similar, not exact, but pretty dang close. Good info so far!
PostPosted: Thu Feb 20, 2014 2:01 pm
boardjnky, sounds spot on!
PostPosted: Thu Feb 20, 2014 3:32 pm
The magic speed is 15mph. That is what makes planing possible. Get over that speed and you can achieve time travel. :-)
PostPosted: Thu Feb 20, 2014 4:23 pm
I've loaded the boat up pretty good on occasions meaning more than my standard plug n play and it did well with the High Altitude prop...
This year I will be running even more weight than last year's plug in play so I thought I would just ask to see if I would see a difference in performance if I did move to a different prop...
2015 T22
Users browsing this forum: No registered users and 61 guests
