It is currently Sat Sep 19, 2026 3:44 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Ronix Eight.3 telescoping and plug and play bags
PostPosted: Mon Feb 17, 2014 5:24 pm
Our shipment of the new Eight.3 bags are on the truck and on the way to us at Boardstop. Should be here any day now.
Ronix Eight.3 Ballast bags
 Post subject: Re: Ronix Eight.3 telescoping and plug and play bags
PostPosted: Mon Feb 17, 2014 7:05 pm
What all will we need for a 2014 A22 to hook up PnP with the Ronix 800s? Will the engine panels need reinforcement with them? Trying to figure out how well they will fit in the rear.
PostPosted: Mon Feb 17, 2014 8:51 pm
Most people are using 3 of the quick connects per bag and then unscrewing the last plug to let the air out of the bag if there is any. That is how most are doing it with the BFI bags. So you would do it the same way with the Eight.3. Another way my techs have been hooking them up is using a Y splitter and then connecting the 4th vent to the overflow. That way you do not have to mess with burping the bag. Not really sure which way is better or if there is much of a difference. I have had them plugged in both ways in 2 different boats and it was the least of my worries.
No sure about the reinforcement on the 800s. The only reinforcement I have heard is on the 1100 bags. The eight.3 are a little tapered because of the trapezoid shape so hopefully they will not lean on the engine panels.
Until more get out on the market and you guys put them to use we will not really know how well they work in the field.
1 - BFI Axis nose bag
2 - Ronix 800 bags
6 - 1" Bag NPT Thread to 1" Quick Connect for Eight.3
6 - 1" Elbow Flow Rite(W746)
4 - 1" quick connects(W743)
PostPosted: Wed Feb 19, 2014 9:47 am
What fittings would a 2012 plug n play model need?
2015 T22
PostPosted: Wed Feb 19, 2014 10:18 am
for 2012 you would need the 3/4 quick connects from Ronix.. I can get those just do not have them on the site. I will do that today.
PostPosted: Wed Feb 19, 2014 10:43 am
So basically everything you said about the 1" in the above post but just 3/4"?
I can just disregard my old fly high connectors?
2015 T22
PostPosted: Wed Feb 19, 2014 1:53 pm
You would still use the red/black quick connectors. I am waiting on the fittings to arrive from ronix to verify but they flow-rite connectors should be the same.
I added them. they are the 1" NPT to 3/4" quick connects. I talked with Ronix today they are in stock.
PostPosted: Wed Feb 19, 2014 5:24 pm
Thumbs up to admin for setting up axis owners correctly
PostPosted: Wed Feb 19, 2014 8:30 pm
So so so tempted to be a guinea pig and try these out in my A20 compared to my Fly Highs...would be great to go up to the 800s (have 400s in there now).
2012 Axis A20
PostPosted: Thu Feb 20, 2014 10:09 am
I've run the 800s in my a20. With cinco prop and wedge, it struggles to get on plane. I'll probably end up settling on sumo 900s and just not fill them all the way for wake boarding.
