It is currently Wed Jan 14, 2026 8:38 pm
 Post subject: someone with a measuring tape, help me out!
PostPosted: Thu Feb 06, 2014 3:13 am
currently at work in the gulf so i cant do this myself. shopping for a garage door to frame into a shop on the property im buying, but i wanna make sure the boat on the trailer will fit! can anyone measure their a22 from the ground to the top of the tower for me? wouldnt hurt to get the fender to fender width too!! greatly appreciated, come down to lake conroe i'll buy you a brew unit, for your troubles.
 Post subject: Re: someone with a measuring tape, help me out!
PostPosted: Thu Feb 06, 2014 3:54 am
10' 3" is mentioned here - viewtopic.php?f=14&t=1631&start=10.
This person went 10' 10" for the door - viewtopic.php?f=16&t=765.
Total Width on Trailer 102"/2.59m at guide posts
PostPosted: Thu Feb 06, 2014 9:29 am
Speaking from experience and someone that had to break down the tower, (with 2 REV 485's) each time.
Bottom to top is indeed 10'3" or very close to it.
The boat storage where I keep my boat had opening only 10' high.
I looked into having me a building built in side of yard but got sticker shock. Cement and bigger door were main expenses.
After talking with my dealer they come up with a solution for me. They lowered my trailer a couple of notches and put a smaller rim/profile tire on there to keep it from rubbing fender. I took off the top light and equipped it with quick connect fittings and my trailer fits now by 1/2".
Just an idea if you had the option of storing it somewhere. Seems 10' high doors are a standard.
Good Luck.
Also keep in mind that if you do a roll up door then you will have to account for the roll up space for the door. Cant remember but 18" sounds about right.
If installing a garage type door I think you only have to add around 6".
PostPosted: Thu Feb 06, 2014 2:21 pm
Go with a 12 x 12 and you will be glad you did, I just had one put in with remote opener and it was around 1500$ for everything
PostPosted: Thu Feb 06, 2014 7:28 pm
thanks dudes,
unfortunately, i dont think i have the room for a 12 ft door, and im not sure that i have the room for even a 10fter with the space needed to roll up... maybe one of those straight track jobbers, but im pretty sure i see boat storage in my future till i get my new shop built.
Users browsing this forum: No registered users and 90 guests
