It is currently Thu Sep 10, 2026 7:45 pm
Post new topic Reply to topic  [ 268 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 27  Next
 Post subject: Re: Home made "Poor-gate"
PostPosted: Thu Sep 26, 2013 12:16 pm
I hope we can get to 15 for that 40% off.
Also I forgot to post a tweak I did to my poor-gate. I got tired of the clamps and wanted a more solid mount. I drilled two holes thru the lip of the swimdeck w/ a 1/2" bit. (I figured if it didn't work I could just repair it w/ fiberglass. I use quite a bit on all of surfboards). After drilling the holes I then cut an exact length of copper tubing and threaded it thru the holes. I sealed the lip where the tubing meets the deck w/ a marine sealant. I drilled matching holes on the poor gate mount and threaded bolts thru and secured w/ wingnuts. The thing is rock solid and seals up against the hull. Still easy on, easy off but much more secure.
PostPosted: Tue Oct 15, 2013 9:48 pm
This is a winter project for me as well.
Thanks for all the ideas guys.
PostPosted: Wed Oct 16, 2013 2:01 pm
has anyone done a full on powered gate yet?
 Post subject: Re: Home made SurfGate
PostPosted: Fri Oct 25, 2013 6:30 pm
1joeyh, is very cool your gate what year is your boat and you ride goofy??? A have a a22 2009 it is the same dimension at your gate??? What speed you ride your boat with the gate thks you i do this during the winter....
PostPosted: Sat Oct 26, 2013 5:52 am
Thanks. Mine is an '09 A22. I ride goofy. I ride at 12.6 mph but my speedo isn't calibrated and I think it might be a 1/2 mph fast. So probably more around 12.
PostPosted: Mon Oct 28, 2013 6:00 pm
Ok thks you:)
PostPosted: Mon Nov 25, 2013 12:11 am
joey how much for you to make both side goofy and regular? haha i currently have a speaker build winter project and a house remodel going! i have a 2010 so same swim platform! you name the price!
PostPosted: Mon Nov 25, 2013 7:23 am
Sent ya a PM
PostPosted: Mon Nov 25, 2013 2:26 pm
Ill have one that can be used on either side of the 2009-2011 swim platform.
PostPosted: Tue Nov 26, 2013 9:19 am
Please post pics when u do. I initially tried making a universal gate for both sides but found it difficult due to the angles required for each side. The dedicated one sided gate made a much better wave.
