It is currently Thu Nov 19, 2026 12:06 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Axis Surf Gate Measurements - 2014 Axis A22
PostPosted: Sun Oct 13, 2013 6:19 pm
Oh, my measurement are .25 in accuracy. Pretty much they are perfect.
PostPosted: Sun Oct 13, 2013 9:32 pm
Thanks for doing those measurements dezul. I am new to the site. I am in the process of makeing my 2012 a20 have surf gates mounted with actuators but it would save a lot of time if u could get the model of the actuators or just the length of the stroke and also the whole actuator retracted end to end. Thanks again.
PostPosted: Mon Oct 14, 2013 4:55 am
Malibu/axis uses Lenco 102 actuators. 4.25" stoke I believe.
PostPosted: Tue Oct 15, 2013 2:57 pm
Can you get a deployed pic and measurements? I realize that I might be easier said then done
PostPosted: Tue Oct 15, 2013 4:06 pm
Thanks for all the pics and for the file dezul and Doug, as soon as my HDPE gets here I'm gonna be under way on mine, getting a head start
PostPosted: Tue Oct 15, 2013 4:42 pm
You should cut a cardboard or plywood cutout first just to ensure it matches perfectly on your boat.
PostPosted: Tue Oct 15, 2013 5:34 pm
Glad to help. I think you will want to cut the template the other way ....
PostPosted: Tue Oct 15, 2013 5:36 pm
Where did you order the HDPE and many sqft? THanks!
 Post subject: Axis Surf Gate Measurements - 2014 Axis A22
PostPosted: Tue Oct 15, 2013 5:53 pm
I used the amazon link in the poor gate thread, it was 3/4" thick and 24" X 52". It was 89$,I ordered one in black. I haven't finished cutting it out, I wanted to leave the measurements intact until my material comes in, the lines on my printout weren't exactly the same measurements, I need to put a straightedge to it and trace out the dimensions.
PostPosted: Mon Oct 21, 2013 12:25 pm
There has to be a way of manually activating this like the wake plate. I was wondering if there is a way of attaching to the transom, where the swim platform is. With out damaging hull. I have a 2013, would love to attach and take off with out drilling holes. I wish they would just come out with retro fit one.
Lake Lanier Georgia
Axis A22 2013
