It is currently Fri Jul 03, 2026 11:31 pm
 Post subject: checking your transmission and Vdrive fluid
PostPosted: Thu Aug 29, 2013 12:21 pm
Check them when warm? Check when running in nutral or check when off?
2012 A22
 Post subject: Re: checking your transmission and Vdrive fluid
PostPosted: Thu Aug 29, 2013 12:26 pm
I dont think is matters, but im not an expert on vdrive's.
PostPosted: Thu Aug 29, 2013 2:22 pm
My ZF manual states that it can be hot or cold when checking. It states to check the level before starting, and then after the engine has run for a bit in neutral (and been stopped) to allow l the oil cooler and pipes to fill. I'll post an image from the manual.
PostPosted: Thu Aug 29, 2013 2:46 pm
