It is currently Sat Jul 04, 2026 5:48 pm
[ 5 posts ] |
sprfrkr
Post subject: Replacing Ignition Key Posted: Mon Aug 19, 2013 11:58 am |
Dave.Mishchenko
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 12:21 pm |
Joined: Fri Aug 20, 2010 5:21 pm Posts: 336 Location: Vancouver
It'll be a 4 position (Accessories - off - run - start).
_________________ 2009 - A22
AJWest
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 12:24 pm |
Anyone else have the ignition/key switch come loose and rotate? Mine's done it a few times.
sprfrkr
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 12:35 pm |
Ahh, thanks Dave, I did not realize that. I may just put the acc on the run pole in that case. I have the radio on the acc switch now.
AJ, there is a nut on the back of the switch which you should be able to tighten.
kyson
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 2:03 pm |
| Boater |
Joined: Thu Jul 11, 2013 10:58 am Posts: 49 Location: Austin, TX
Yes- mine was loose and rotating within a couple of hours. I tightened it by hand on the water and it's been ok since.
Additionally, my wedge down indicator was lit while the wedge was up. I had to bend the tab on the transom switch slightly and it's been fine since as well.
H
[ 5 posts ] |
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 42 guests |
