It is currently Sun Sep 14, 2025 6:20 pm
[ 4 posts ] |
Author |
Lakewake
Post subject: Front plug and play arrow bag will not drain Posted: Tue Aug 06, 2013 9:01 am |
Newbie |
I recently installed the front arrow plug and play (950 lb) bag in my 2013 A22, and it will not drain unless I remove the seats and stand/lightly hop on the bag. It seems there is an air build up and by standing on the bag it releases the air and then the water flows.
I installed the bag myself and it fills and overflows fine. When I installed it I simply removed the plastic Y piece and installed the bag without shortening the hoses. Will shortenening the hoses have any effect on this problem? Any other remedies?
Also, when I fill the front bag totally full, the seat cushions pop up (no chilax seating) as if the bag is too big. Is this normal?
Thanks!
Top |
Axis Of Evil
Post subject: Re: Front plug and play arrow bag will not drain Posted: Tue Aug 06, 2013 9:40 am |
Team Axis |
Joined: Tue Aug 14, 2012 1:19 pm Posts: 77 Location: Grand Rapids MI
It sound like your drain pump is losing its prime, do you have to stand on it the whole time or just to get it started? My front sac does the same thing with the fill hose, but once the water starts to flow it's fine.
And yes it's normal for the bag to pop the seats up when it gets full, I keep my chillax seat up when its full for this reason.
_________________ -Pat
Top |
Lakewake
Post subject: Re: Front plug and play arrow bag will not drain Posted: Tue Aug 06, 2013 12:10 pm |
Newbie |
I only need to stand on it to get the water to start draining, then its fine after that and will empty fully. Any remedies?
Top |
Ferral
Post subject: Re: Front plug and play arrow bag will not drain Posted: Wed Aug 07, 2013 7:50 pm |
Team Axis |
Which port did you use for the drain? I moved mine to the rear most port and that worked much better than where my dealer had it.
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 111 guests |
