It is currently Tue Nov 04, 2025 11:58 pm
 Post subject: A22 Won't Start (w Video)
PostPosted: Fri Jul 08, 2011 3:56 pm
Ok, so she won't crank over now. Any help or leads would be appreciated.
Here is the video: http://www.youtube.com/watch?v=DyBBNf5jTGg
(Don't worry, I only cranked it a few times to avoid burning the starter out)
So, filled up w gas yesterday on the water and rode for an hour with no issues. The tank was only half empty when I fueled up.
Today, started no problem. Rode for an hour.
Each switch of riders it became harder and harder to start.
Finally, it stalled when trying to launch a rider.
Limped back to the dock. Was really tough to start.
Added octane boost, fuel drier, and stabil to gas. Still 3/4 of a tank on gauge. Rocked boat an tried cranking a few more times. Took the above video then.
Last week:
Same thing happened. Lost gas cap and it poured so I used the above items to dry it out if there was water in it. After mixing it a bit and cranking it a few times, it started and ran rough. It eventually cleaned up and ran strong the rest of the weekend. It did pour again last night, but I made sure my makeshift gas cap was more secure this time.
Other:
- Oil is clean, ATF is clean. Fuel pressure fine when running. Temp is 170. Air is 80 degrees. Dual batteries.
- Indmar Salt Cat 400
- Boat is two weeks old
Any thoughts or leads are appreciated,
Shannon
 Post subject: Re: A22 Won't Start (w Video)
PostPosted: Sun Jul 10, 2011 9:35 pm
sounds like you may still have water in the system...possibly empty and flush fuel rail and lines...then put an inline filter in
