It is currently Mon Sep 21, 2026 5:53 pm
 Post subject: FAE install problems.
PostPosted: Fri Jul 19, 2013 4:26 pm
I have a 2013 A22 and i'm trying to install an FAE. Has anyone installed one on a '13 yet? I'm about halfway through the install an put the swim platform back on to line it up and the platform is sitting on top of the FAE, there is absolutely no clearance. I have a call in to the company but was looking for any advise/help any one can give.
 Post subject: Re: FAE install problems.
PostPosted: Fri Jul 19, 2013 8:44 pm
I did and I can tell you I ran into the same issue. I basically had to throw the directions out and come up with my own mount points. I was however able to do it with the parts I had.
Good Luck
PostPosted: Fri Jul 19, 2013 8:59 pm
Give Larry a call.
PostPosted: Fri Jul 19, 2013 9:12 pm
If you haven't seen this thread yet here's the one I put on mine, viewtopic.php?t=1644 I did like Jason and made my own bracket, I wanted to keep it off my swim platform just in case I need to remove it, and it's much more solid mounted to the wedge, drilling through stainless is a pita but the end result is worth it, johnny and joey also have FAEs on their boats, pics can be found if you search for em, Larry is a good guy and will help you out any way he can
PostPosted: Sat Jul 20, 2013 8:46 am
Thanks guys, I've talked with Larry about it and I'm sending him pics. Walter your set up looks great but I noticed you've got about an inch of clearance from the top of the FAE to the bottom of the platform. When I put my platform on it actually pushes down on the FAE. Just doesn't seem good for either the boat or the exhaust.
PostPosted: Sat Jul 20, 2013 9:14 am
Might need to take a chop saw and knock an inch off the extension pipes, put some pics up here too.
