It is currently Fri Sep 25, 2026 6:14 am
 Post subject: dead on water
PostPosted: Sun Jul 07, 2013 2:40 pm
I am out on river right now, key is turning freely and not starting boat, any suggestions?
Thanks
 Post subject: Re: dead on water
PostPosted: Sun Jul 07, 2013 2:47 pm
Check you emergency cut off lanyard.
PostPosted: Sun Jul 07, 2013 2:48 pm
Is the engine turning over (cranking) but not starting?
Lanyard is located below the shifter red coiled cord.
PostPosted: Sun Jul 07, 2013 2:50 pm
Make sure your shifter/throttle is in neutral
PostPosted: Sun Jul 07, 2013 2:57 pm
Yes checked, both, it's the ignition switch, it will turn 360 degrees
PostPosted: Sun Jul 07, 2013 3:12 pm
Which two wires can be used to jump start the boat
PostPosted: Sun Jul 07, 2013 3:23 pm
Should be a red or orange and back or other dark colored wire.
PostPosted: Sun Jul 07, 2013 11:21 pm
Was your ingnition switch just loose from the back allowing the key to spin?
PostPosted: Mon Jul 08, 2013 10:52 am
Same thing happened to me last fall. My switch had to be replaced.
Users browsing this forum: Majestic-12 [Bot] and 54 guests
