It is currently Mon Nov 02, 2026 8:46 pm
 Post subject: Sub Box Install 2012 A22 Vandall
PostPosted: Mon Jun 24, 2013 11:32 am
Finally got around to installing a sub box. I have sound pack 3 with wet sounds, and it is unbelievable the difference a box makes for that sub. We also put in mirrors in the box and leds on the back of the box inside and underneath, so it glows through the vent on the bottom.
 Post subject: Re: Sub Box Install 2012 A22 Vandall
PostPosted: Mon Jun 24, 2013 11:44 am
Pictures didn't attach!
PostPosted: Mon Jun 24, 2013 12:45 pm
Looks good! Did you build this one yourself?
PostPosted: Mon Jun 24, 2013 1:51 pm
I had a guy build a box for me. I helped with the install and also put in the screen at the bottom and modified the carpet!
PostPosted: Mon Jun 24, 2013 2:02 pm
That's freakin cool!
PostPosted: Thu Jun 27, 2013 11:56 am
That is SICK! Want to build another?
PostPosted: Thu Jun 27, 2013 6:48 pm
That's probably one of the best setups I've seen in an Axis. Good job
PostPosted: Thu Jun 27, 2013 7:09 pm
That is clean!!! What speaker did you use?
PostPosted: Fri Jun 28, 2013 7:38 am
The sub is the XS-12 Wetsounds. I'm sure my guy would build another but not sure if he would be will to ship it. It is actually a 2 piece box. The sub is in a box by itself with a 3/4" plexi glass on the front and its bolted to the floor, then you install the front plate. Makes it really easy to get behind there, only 6 stainless steal screws! And it looks like 1 piece! I can't believe the difference that sub makes when it's in a box properly vs. being mounted in plastic!
PostPosted: Fri Jun 28, 2013 8:09 am
Where are you located? If shipping is not an option, can you give us the dimension and a couple more pics of the inside box?
Users browsing this forum: Majestic-12 [Bot] and 3 guests
