It is currently Sun Sep 20, 2026 10:23 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: Wakesurfing set up
PostPosted: Thu Jun 27, 2013 10:01 am
They can be off a few mph at wakeboarding speed - viewtopic.php?f=14&t=195
PostPosted: Thu Jun 27, 2013 10:06 am
Str8inok wrote:
That is with 750 sack full in port rear, almost full front 950 bow sack under the seats. 3 adults on port side bench. Speed was around 11 set on the cruise control
Your speedo must be way off at surf speed. I never see a surf wake that ugly at 11mph. Looks more like 8mph
PostPosted: Thu Jun 27, 2013 10:11 am
Awesome I will have to get my lowrance off my bass boat and figure that out. I do a lot of boarding in a navigation channel, will current have effect on speed being off?
PostPosted: Thu Jun 27, 2013 10:13 am
This is what it looks like as soon as I get pulled up before cruise dials in.
PostPosted: Thu Jun 27, 2013 10:18 am
That looks better than the first pic does but good lord that a ton of roost coming up from the prop.
PostPosted: Thu Jun 27, 2013 10:19 am
Every one I have read says spedo reads +2mph @ wakeboarding speeds. My surf speed was off by +1mph. I recalibrated at both.
PostPosted: Thu Jun 27, 2013 10:20 am
How deep is the river?
PostPosted: Thu Jun 27, 2013 10:24 am
15 to 20ft
The wedge may of been down in that pic...
PostPosted: Thu Jun 27, 2013 12:25 pm
Stra8inok, since we have paddle wheel, even with a current the boat will run the correct speed compared to the water. But it will be off from your gps since the GPS does not factor in the current. GPS will basically measure your speed compared to land which is not what you want. So keep that in mind if you try to calibrate with a current. GPS should read slower than actual upstream and faster than actual when going downstream.
Users browsing this forum: Google [Bot] and 36 guests
