It is currently Mon Nov 23, 2026 4:39 am
 Post subject: 750's or 1100's that is the question
PostPosted: Thu Jun 13, 2013 6:33 pm
don't want to have to mess around with adding lead bags or more people to the surfside. should i just go for the big boy 1100's ? any prop suggestions??
 Post subject: Re: 750's or 1100's that is the question
PostPosted: Thu Jun 13, 2013 7:22 pm
Straight line 900s. It's a good balance between the 750s and 1100s. Prop, no debate, 2315 from Acme, hands down.
PostPosted: Thu Jun 13, 2013 7:46 pm
if you are going to surf and are going BFI bags then the 1100s. If you are going sumo then the 900s. At least a 1235. better would be the 2315.
PostPosted: Thu Jun 13, 2013 10:30 pm
If you usually have a medium sized crew onboard then 750's plus people ballast will work. If you only have 4 or less get the 1100's.
PostPosted: Fri Jun 14, 2013 5:42 am
thanks, think im gonna go with the 1100's, did you guys have to reinforce the engine compartment?? if so what did u use?
PostPosted: Fri Jun 14, 2013 7:39 am
I have 1100s and reinforce ment was a must. I used powdercoa t ed adjustable shelve rails from lowes. I posted some pics here a whi le back.
PostPosted: Sun Jun 16, 2013 7:17 am
757 -- here is a link to one of the threads discussing the engine compartment dividers and reinforcement for reference. You will love the 1100's for surfing and i run the 1235 and have no issues (but i do not wakeboard either).
Good Luck!
viewtopic.php?f=14&t=1698&p=9223#p9223
PostPosted: Sun Jun 16, 2013 9:35 am
I've got 950 and 600. Wish I'd gone bigger. 1100 all the way for surfing if your big guy.
Lake Lanier Georgia
Axis A22 2013
PostPosted: Sun Jun 16, 2013 10:44 am
cool thanks for the help!
Users browsing this forum: No registered users and 77 guests
