It is currently Sun Nov 02, 2025 1:35 am
 Post subject: Questions
PostPosted: Sat May 25, 2013 9:56 am
Couple of questions about gas I want to quick confirm.
1) how do I know the tank is full / close to full?
2) I should be using regular gas, correct?
Thx
 Post subject: Re: Questions
PostPosted: Sat May 25, 2013 10:29 am
I usually listen to the gas going in and can usually tell when it is getting close to full by the way it sounds going in. However today I wasn't listening too well and it overflowed when filling. I then spent the next 10 minutes there at the gas station cleaning and wiping down the side of the boat.
I use regular gas in mine. Unless you have the corvette engine then I have heard regular gas is fine. Have a friend that has the engine upgrade and they run premium in theirs.
Hope that helps.
Thx
PostPosted: Sun May 26, 2013 7:37 am
I use blended Octane in my 2012 A22 (89 OCT in TX); no problems with starting, smoke, or knock.
PostPosted: Wed May 29, 2013 12:43 pm
91 only goes in my LS3, the AR335 (now badged as the 330) is okay on 87.
I found it very difficult to fill the tank with the pump unless I actually hold the handle upside down and pump. Then it fills quite well and you can hear it start to fill up the neck and I'll shut off the pump then. Fuel gauge reads full when my tank is full... Does yours malfunction?
Axisowners
PostPosted: Wed May 29, 2013 1:42 pm
Manual says 89 for the 335
Users browsing this forum: No registered users and 70 guests
