It is currently Fri Oct 30, 2026 6:46 pm
[ 7 posts ] |
AJWest
Post subject: RGB's installed finally Posted: Sun Apr 22, 2012 11:07 am |
wvidal
Post subject: Re: RGB's installed finally Posted: Sun Apr 22, 2012 12:47 pm |
| Axis Owner |
Joined: Tue Apr 27, 2010 7:39 pm Posts: 122 Location: Chattanooga, TN
sweet they look good! a little trippy but cool
DatTexasBoy
Post subject: Re: RGB's installed finally Posted: Sun Apr 22, 2012 7:38 pm |
Joined: Thu Dec 15, 2011 7:57 am Posts: 779 Location: East Texas
Nice. I have a friend that owns a lighting store and is thinking of adding some of these to his boat....
_________________ 2010&2014 A22 2012&2015 MB 2016 Supra SA400
nastya20
Post subject: Re: RGB's installed finally Posted: Sun Apr 22, 2012 7:56 pm |
Looks good AJ. You do the install? Which led and controller did you use?
AJWest
Post subject: Re: RGB's installed finally Posted: Mon Apr 23, 2012 7:57 am |
Matt, took about 3 hours to do the install. Trying to run/fish the wires and wire loom took most of Tge time. No panels were removed during the install. I'll get the part numbers for you tonight when I get home.
morrisdl
Post subject: Re: RGB's installed finally Posted: Mon Apr 23, 2012 3:17 pm |
Thanks for sharing. I would be interested also.
AJWest
Post subject: Re: RGB's installed finally Posted: Tue Apr 24, 2012 9:27 pm |
From Super bright LEDs. On my A22 I used two - WFLS-RGB30 (39" strip); three - WFLS-RGB15 (19" strip); 35 ft extra wire RGB-4Wire; controller - LDRF-RGB4: RGB Controller w/ RF Remote; five - EC10: 10mm Silicone End Cap (for any need to cut the strips to size). I used some clear double sided PVC tape to stick the strips because it's stronger than the 3M adhesive that is on the strip. You could also use the rigid strips and cut them to size.
[ 7 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 8 guests |
