It is currently Fri Nov 20, 2026 1:04 pm
 Post subject: How to remove upholstery
PostPosted: Fri Jun 04, 2021 3:30 pm
I have a 2015 Axis A22. The grab bar in the bow seating area on the starboard side has come loose. One end is totally missing a nut and the other end the nut must be loose. I can only figure the way to reach it is by removing a part of the upholstery directly below that grab bar. Has anyone done this that can give me advice?
 Post subject: Re: How to remove upholstery
PostPosted: Sat Jun 05, 2021 10:51 am
You might be able to go through the cupholder holes. Might be too far away though.
In my 2014 A22 I can lift the center cushion and there’s a big hole underneath.
The upholstery is bolted from behind as well, so I guess removing that will be as difficult as reaching the grab handle.
2014 A22
PostPosted: Mon Jan 17, 2022 1:47 pm
Can you reach it by removing the speaker??
Users browsing this forum: Google Adsense [Bot] and 7 guests
