It is currently Fri Apr 17, 2026 8:44 am
 Post subject: Winterize and Ballast Not Filling
PostPosted: Tue Sep 22, 2015 8:11 pm
Hey Yall,
As you can tell from my previous posts if you saw them I just got a 2010 Axis A22 Vandall edition. I have been having a few problems with it. The back right ballast now won't fill. I am not the most handy person in the world, but I am learning. Are there common things to check for?
Side note. Instead of paying someone to winterize the boat for my every year for the rest of my life I figured it's time to learn. Anyone have any advice on winterizing the a22 ? I live in north GA and planned to drain the block. Perhaps pump it back with antifreeze some how. Also, I am assuming I will have to some how get the water out of the ballast system as well. Let me know any helpful hints.
Thanks!
 Post subject: Re: Winterize and Ballast Not Filling
PostPosted: Tue Sep 22, 2015 10:35 pm
Is the pump turning on for the ballast?
PostPosted: Wed Sep 23, 2015 4:35 am
here is a thread on winterizing viewtopic.php?f=14&t=284
PostPosted: Sat Sep 26, 2015 8:50 am
If the pump is running it may be air locked. I have a 2012 vandall and my left rear for some reason gets air locked when I never have issues with the right rear. To fix it just get the boat on plain and turn on the pump/ballast switch and it fixes the air lock for me and it's good for a while again.
