It is currently Sat Oct 10, 2026 9:33 pm
 Post subject: Sub and Amp Install Question
PostPosted: Wed Feb 12, 2014 6:35 pm
I myself am going to install the factory Alpine sub and amp in addition to my two 800.4 Exile amps that run my tower speakers. Can anyone give some advice on the amp kit and wiring instructions on how they would tie the sub/amp into my current set up? Thanks guys.
2015 T22
 Post subject: Re: Sub and Amp Install Question
PostPosted: Wed Feb 12, 2014 8:35 pm
Have you ever hooked this stuff up before? I am guessing you will need a couple of 4 guage amp kits. I would order them from sonicelectronix.
PostPosted: Wed Feb 12, 2014 8:50 pm
Yes I hooked up my tower speakers and amps with Brian from Exile on the phone basically walking me thru it...
Just wanted to get a 2nd opinion on this alpine equipment set up before I started into it.
2015 T22
PostPosted: Wed Feb 12, 2014 9:05 pm
Which sub did you get? Is it single voice coil or dual voice coil?
PostPosted: Wed Feb 12, 2014 9:08 pm
Search online on how to install an amp and it should walk you through it. It is pretty simple. Once you wire it correctly, the tuning will come.
PostPosted: Wed Feb 12, 2014 9:12 pm
It's the SWS 12D4
2015 T22
PostPosted: Wed Feb 12, 2014 9:24 pm
What amp do you plan to push it with?
PostPosted: Wed Feb 12, 2014 10:11 pm
I have the Alpine MRV M500
2015 T22
PostPosted: Wed Feb 12, 2014 11:37 pm
Sounds like it will thump.
