It is currently Fri Apr 17, 2026 7:26 am
 Post subject: Building a surf pipe
PostPosted: Mon Apr 30, 2018 10:15 pm
I’ve been thinking about a surf pipe recently but was not sure about getting one. Mostly concerned about loosing access to the wedge. So rather than buying one I was not sure of, I figured I’d build it and be sure I had the clearance I wanted.
I started by mocking up with some 4” ducting to get an idea of the shape.
Next it was time to get serious with a bandsaw and some 4” exhaust tube from a local muffler shop. I cut it in a bunch of 30 degree wedges. Rotating them gives an infinite amount of angles. It took a while but I finally got it into a shape I liked. Blue tape was key to holding the pieces together as I fitted and adjusted.
After a lot of welding and grinding, the final piece came together. It may not a piece of art but it will do.
It’s made of mild steel (because that’s what I can weld) and corrosion protection is a big concern. What do I paint it with?
 Post subject: Re: Building a surf pipe
PostPosted: Tue May 01, 2018 3:58 am
Nice, but should have done stainless and tiged it, paint won't last even the high temp crap look into getting it thermal coated imo
PostPosted: Wed May 02, 2018 5:21 am
Have you thought about using something like POR-15?
PostPosted: Wed May 02, 2018 10:09 pm
Stainless is the obvious choice but requires tools that I don’t have, including a tig welder.
Powder coating is out because they cannot do the inside. I am going to try some high temp engine block paint and see what happens. If it does not hold up then I will investigate some more aggressive options like the por-15.
PostPosted: Thu May 03, 2018 9:10 am
Engine block paint will be more than enough. It can't possibly get that hot, it's sitting IN the water for crying out loud.
PostPosted: Thu May 03, 2018 9:11 am
Also, make sure you drill a drain hole in the bottom of the flat part. Ideally at the lowest point, so that water doesn't sit in the bottom of the pipe.
PostPosted: Sat May 12, 2018 6:26 am
Where did you buy the flanges?
PostPosted: Sat May 12, 2018 8:13 am
The mounting flange was made by hand. I made a template out of card stock and then transferred that to a sheet of mild steel from Home Depot. A little patience and a fair amount of filing and it worked out pretty good.
PostPosted: Sat May 12, 2018 8:50 am
I'll just have my buddy do them on his plasma table out of ss cause I need 2
