It is currently Fri Apr 17, 2026 8:52 am
[ 4 posts ] |
r33pwrd
Post subject: Fuel filter? Posted: Fri Sep 11, 2015 8:22 am |
Joined: Sat Jun 06, 2015 10:35 pm Posts: 1181 Location: Sammamish WA
Does the a24 with 6.0 have an inline fuel filter? Boat is cranking longer than normal to start and was going to do plugs and fuel filer..
_________________ -2015 A24 - 409 HP - 2249 Prop - 1100 rear sacs - 950 front sac - 290lb rider with Red Rocket and Phase 5 Quest
ThatGuy
Post subject: Re: Fuel filter? Posted: Fri Sep 11, 2015 10:07 am |
Joined: Thu Jan 08, 2015 6:29 pm Posts: 538 Location: Ohio
I have no idea. But I'm curious, how many hours do you have to think this might be the issue? Hope you get it figured out.
_________________ 2015 T22 - SOLD
r33pwrd
Post subject: Re: Fuel filter? Posted: Fri Sep 11, 2015 10:15 am |
I have just under 110 hours... but 90 of that is surfing
dustinjean
Post subject: Re: Fuel filter? Posted: Fri Sep 11, 2015 3:47 pm |
Joined: Wed Sep 03, 2014 5:19 am Posts: 457 Location: Mt. Washington, KY
not sure on the 2015 but on my 2014 with the 6.2 if im in the starboard rear locker and remove the engine panel you can see it up towards the transmission. It uses the exact same quick connect fittings as gm vehicles as far as i can see, so you will need the disconnect tools which are a couple dollars at any auto parts store. You might even be able to get to it easier by sliding the skybox seat up and get to it that way.
_________________ 2014 A24
[ 4 posts ] |
Users browsing this forum: Google Adsense [Bot] and 1 guest |
