It is currently Sat Mar 14, 2026 12:10 am
 Post subject: 2017 A24 plug n play bags
PostPosted: Tue Apr 25, 2017 9:08 am
Team,
I have an A24 on the way. Looking to add to the plug n play system. I see Wakemakers custom set up with 825s in the rears and 390 in the bow. This sounds woefully short. What's the scoop here? I was thinking Sumo 900s in rears and sumo 750 under seats in bow. Will this sack fit under seats in bow? Also want to keep 1-1/8" fittings for flow rate.
Would love some experienced insight. Thanks.
 Post subject: Re: 2017 A24 plug n play bags
PostPosted: Tue Apr 25, 2017 12:51 pm
Under the bow is small, if you want more bow weight add some lead or a walkway bag
PostPosted: Tue Apr 25, 2017 1:29 pm
burt77 wrote:
Team,
You can get a 2000lb sac for the bow but it's still going to fill to the 390-400 lbs wakemakers is saying. Space is space and it will only hold so much. Wakemakers actually went to Malibu and laser measured the lockers and bows of all the boats and made the bags to the exact fit and based off the measurements is how they got the weights. I was out in a 17 A24 and we had the new stepped fly high 550s and when full we had about 6" of storage left. The 750s would of filled the lockers completely.
PostPosted: Tue Apr 25, 2017 3:50 pm
Thanks for the confirmation. The last thing I want to do is have to add a manual fill sack (currently have an '05 23LSV where I'm manually filling sacks). I have 200# of lead I can finagle with.
PostPosted: Sat Jun 03, 2017 10:31 pm
You'll be filling an on cushion bow seat unless you plumb it in to fight bow rise and lengthen wave from the bigger rears anyway, see if dealer can plumb that in with a reversible pump and a fitting for a two ended quick connect hose and get a kinetic vent from drip depot or you will be manually filling that sac, you need a minimum of a 600, many will use a 1000
PostPosted: Sun Jun 25, 2017 10:03 am
Where did you add the extra reversible pump? There is so little real estate when you get into the hull with all that's buried down there. Any pictures you can share? I was just speaking with my dealer about this exact thing on Friday.
2015 T23 - Sold
2018 ???
