It is currently Sat Oct 31, 2026 10:52 pm
 Post subject: Installing Heater on 2012 A22 w/ Indmar 335
PostPosted: Fri May 27, 2016 1:03 pm
Hey everyone, I'm new to the site...just purchased my boat a few weeks ago. I bought a heater and am planning to install it under the front passenger seat in my 2012 A22. I was wondering if anyone has done this before. Where do tie into the existing coolant system? Can anyone point me to an old thread? I feel like running the lines will be pretty simple, and I have a factory 2-way accessory switch I can use (which is awesome). All I'm really worried about is making sure I cut the existing hose and branch in at the right spot on the motor.
Any help would be greatly appreciated!
 Post subject: Re: Installing Heater on 2012 A22 w/ Indmar 335
PostPosted: Fri May 27, 2016 2:24 pm
You don't need to cut anything if you don't currently have a heater. Just remove a couple plugs. I have photos somewhere from when I did mine I'll dig them up a little bit later.
PostPosted: Fri May 27, 2016 3:17 pm
On top - to heater
Left side not the rusty one the brass one that's vertical - from heater
