 Post subject: Plug and play fill time to estimate weight added to boat
PostPosted: Sat May 14, 2016 3:10 pm
Does anyone know how many gallons per minute the T22 takes on so i can estimate the weight distribution if I don't want to fill the entire hard tank plus extra ballast bags the boat has around 3000b total ballast capability.
I purchased the boat used and I don't need 3k lbs all the time. there are two 750lbs in back and then a sac up front as well plus hard tanks.
Unless there is some other way to factor how much ballast I am adding.
thanks
 Post subject: Re: Plug and play fill time to estimate weight added to boat
PostPosted: Sun May 15, 2016 12:01 am
I was told at the dealer 100gal/min.
Toy Store:
2016 A22 Green/White
2009 Built Jeep Wrangler
1978 Bandit Trans-Am
PostPosted: Sun May 15, 2016 8:26 am
thanks
this would make sense. so 100 gallons a minute or 800 lbs per minute.
if everything were perfect. or about 5 minutes to fill the boat..
thanks
PostPosted: Sun May 15, 2016 8:48 am
Sorry edited my post (must have been a late night) should have said gallons per minute. So for example my rear hard tanks + 750lb sacks take about 10-11 min. I never timed them but that feels about right.
Toy Store:
