It is currently Fri Oct 30, 2026 3:44 pm
[ 4 posts ] |
coversjim
Post subject: Wetsounds problem Posted: Sun May 03, 2015 6:15 pm |
Ordered 2 new rev410 for the tower and replaced my SYN4 with a SD4.
Problem is only 1 of the speakers really works at a time. One of them is loud the other barely has any sound. If I switch the speaker wire around on the amp switches which 410 works normal and the other gets super quiet.
I know it isn't the head unit or the ws420 eq because I ran aux right off the amp to my phone so that isn't even in the loop
Ideas?
Only thing I can come up with is the amp is bad. I have the amp set to bridged and stereo settings.
Thank you.
boardjnky4
Post subject: Re: Wetsounds problem Posted: Sun May 03, 2015 7:45 pm |
It shouldn't be set to stereo on tower speakers, but i doubt that's the problem. You cannot discern stereo vs mono from 70 ft behind the boat.
coversjim
Post subject: Re: Wetsounds problem Posted: Sun May 03, 2015 8:13 pm |
I didn't know I should have it set to mono I will change that.
Don't know that will fix the problem but thanks for the tip
coversjim
Post subject: Re: Wetsounds problem Posted: Mon May 04, 2015 9:42 am |
talked to wetsounds. apparently even tho i have the amp set to channel 1+2 only as i have it bridged. i still need to adjust the gains and high pass for 3+4. going to test and see if this works tonight. user error sounds like.
[ 4 posts ] |
Users browsing this forum: No registered users and 16 guests |
