It is currently Sat Mar 14, 2026 12:59 pm
 Post subject: How many fittings do I need?
PostPosted: Sun Feb 24, 2013 6:21 pm
Ok fellas, I have the front mushroom sac. It has the three of the straight fittings already on the bag. http://www.wakemakers.com/fly-high-pro- ... -w736.html it also already have one elbow http://www.wakemakers.com/fly-high-pro- ... -w742.html and one straight http://www.wakemakers.com/fly-high-pro- ... -w740.html
I'm pretty sure I need one more elbow, w742 and the front will be good to go.
On to the rear! I'm planning on 1100s http://www.wakemakers.com/fly-high-jumbo-surf-sac.html My real question is, how many fittings for the rears will I need? I'm assuming 2 elbows and one straight along with the three screw in quick connects on the bags themselves. Does that make sense? So a total (for the rear) 4-w742, 2-w740, and 6-w736. I want to be able to quickly remove the bags for cleaning and maintenance purposes.
Please can someone confirm this? Many many thanks in advance!
Luke
 Post subject: Re: How many fittings do I need?
PostPosted: Sun Feb 24, 2013 8:57 pm
on the front you will need 2 90deg elbows and one straight, the rear depends on whether or not you point the fittings in the tank forward, if you have turned them get 2 straight and 2 elbows, if you're keeping the fittings pointing toward the engine you'll need 4 elbows. The pnp on the '09-'12 was designed to just use an in and an out, the other ports on the bag need plugs and i'd just use them for burping out air pockets.
4-736 and 4-732
or if you pointed the fitting forward like I did in my how to 4-736 and 2-730 and 2-732
