It is currently Wed Jul 01, 2026 4:08 am
 Post subject: 2014 T22 optimal wake setup.- front vs rear. expert advice??
PostPosted: Sat May 20, 2017 5:32 am
ok I know there are posts on this but I have a t22 with factory hardtanks that should be 250 lbs on port/starboard rears and 400 under center?
- I have 750 lb sacs plug and play in rears..
-650 sac up front that never fills full..
400 in center hard tank? which i can't find.
-wedge
We want the optimal wake wave, am i to understand that front is more important than rear? if i fill up everything to capacity is the 950 total on each side rear to much?
what would be the optimal set up assuming only 4 people in boat.
i would get smaller bags for rear or pull hard tanks.. its impossible to guess when the bags would be partially filled.
I don't want to use lead.
 Post subject: Re: 2014 T22 optimal wake setup.- front vs rear. expert advi
PostPosted: Sat May 20, 2017 6:23 am
That is about the best setup your gonna get with lead or extra sacs laying around.
All tanks Full
750's
Bow Sac
I don't run wedge I like the wave without it. This setup on a t22 should be pretty good but if you want it to get real good add 150 lead to the bow and a sac in the walkway the wave will be legit
PostPosted: Sat May 20, 2017 10:41 am
All tanks Full
750's
Bow Sac
+1. If you want to play around with weight to see what you can change take a bunch of friends and move them around on the boat to see what helps. I have a t22 and considered putting 200lbs of lead in the bow in addition to the pnp. But wave is great for me so no need to drop the money on lead bags in my opinion.
(I use my wedge for surfing. Not wakeboarding)
PostPosted: Sun May 21, 2017 6:51 pm
thanks ill try these and see how they work. the wave is good just want to get it great..
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 10 guests
