It is currently Mon Mar 16, 2026 2:45 am
 Post subject: Amps need replacing...need advice.
PostPosted: Mon Mar 10, 2014 4:53 pm
Here's my current Setup:
Cabin Amp: MTX TE404 - 65W RMS x 4 @ 4ohms
Cabin Speakers x 6: Wetsounds SW-650 - 100W RMS @ 4 ohms
Tower Amp: Trifecta 4200 - 200W x 4 @ unknown ohms - $99 amp on ebay came with boat lol
Tower Speakers x 2: Wetsounds Pro 60 - 150W RMS @ 4 ohms
I have a separate Alpine amp driving the sub which works fine, no issues there.
I'm pretty sure the 4 rear cabin speakers are split into 2 sections run in parallel (left 2 and right 2) to act as 1 rear set on the headunit for balance/fade. The front 2 are each on their own front channel L & R.
The Cabin amp is completely hosed at this point and Tower Amp is so cheap I can't stand it anymore, both of them need to go. My budget is anywhere from $750 to $1000 or so. I may need more or less, not really sure with this audio stuff...looking for some help on what amp I should get to drive my cabin and also a separate amp for my tower speakers.
I was looking at the RockfordFosgate M400-4D for the Cabin and Wetsounds SYN2 for the tower speakers. I wakeboard a lot and am usually riding between 75-80 feet out, we also do a bit of wake surfing.
Thanks in advance for your help!
2011 A20
 Post subject: Re: Amps need replacing...need advice.
PostPosted: Sun Mar 23, 2014 10:37 am
I have the syn2 for my rev10s and have the ht6 which puts out 110x6@4ohm for the sw650s.
2013 A22
