It is currently Sat Sep 26, 2026 3:08 am
 Post subject: Low voltage
PostPosted: Sat Aug 18, 2012 12:22 pm
I noticed when the boat was running the v meter reads 11.8. any ideas on how to troubleshoot?
 Post subject: Re: Low voltage
PostPosted: Sat Aug 18, 2012 12:54 pm
ed, do you have a multimeter, or access to it?
next time your out on your boat, test each battery to read your volts before you drive it to the launch to go out. If you trickle charge you should read normal 12-13v. next, once on the water with the motor running, confirm your low voltage by directly checking alternator (red test to red terminal on alternator and black test to frame ground or anything except the alternator) If it is in fact low just as your display shows, then test each battery while the engine is running, they should be 12-13. Finally, turn off your engine and test your batteries to see if there is any drop (less than 12 immediately probably means bad batteries) Test batteries again after they have been sitting a while (30+ minutes) and see what each read. If your batteries have drained at all, then its probably your batteries, if they have held their charge, then it sounds like your alternator, assuming you have no major draws from your amps and margarita maker :)
PostPosted: Sun Aug 19, 2012 9:11 am
How old are the batteries? Are you using a shore charger to maintain them?
PostPosted: Sun Aug 19, 2012 2:21 pm
Thanks john.
The batteries are a little over two years old. I dont trickle charge the batts every week. But I do charge them.
PostPosted: Wed Aug 22, 2012 8:19 pm
This was happening to me intermittently when I first got the boat escalated to warning beeps and engine cut out. Ended up floating dead in the water in the first week. I fitted dual batteries myself so Luckily I had some tools and a multimeter on board (encase anything went wrong with my wiring) so traced all the wiring etc. and discovered the main supply cable going into the fuse box by the drivers seats was lose in the crimp.
PostPosted: Tue Sep 04, 2012 11:24 am
It ended up being the alternator. Indmar, Malibu/Axis dealer (paradise water sports), and a local Indmar shop (where I keep the boat) worked together and had it taken care of under warranty in time for the labor day weekend. Thanks for working together and getting my fam back on the water.
PostPosted: Tue Sep 04, 2012 3:52 pm
elc, glad see you are back up and running. We will be in Havasu September 20 - 23. Let me know if you guys are going to be out there that weekend.
Users browsing this forum: No registered users and 100 guests
