It is currently Thu Oct 30, 2025 3:56 pm
 Post subject: New to the wakeboarding boat 2011 22a
PostPosted: Tue Aug 14, 2012 3:59 pm
What is the top speed for that boat. is the tower hard to lay down.
 Post subject: Re: New to the wakeboarding boat 2011 22a
PostPosted: Tue Aug 14, 2012 8:53 pm
Top speed is low to upper 40s depending on which prop and how much weight you are carrying. Tower is pretty easy to take down if nothing is mounted on it, but pretty difficult to do without help if you have heavy speakers on it like I do.
PostPosted: Sun Aug 19, 2012 3:08 pm
what is the best prop for this boat. are your seats ripping.
PostPosted: Sun Aug 19, 2012 3:33 pm
i took tower down do yall just lay it on the back seat. or do they make a stand for it.
PostPosted: Sun Aug 19, 2012 4:35 pm
I would use something other than the back seat to rest the tower on. The back seat already gets enough abuse from getting in and out of the boat in the back. A simple 2 x 4 piece of wood should work. Hope this helps.
PostPosted: Sun Aug 19, 2012 8:04 pm
Yeah I would think leaving weight on the seats all the time would cause the vinyl to permanently deform after a while. I would definitely make a stand if I was folding down.
As for which prop is best, there is no right answer as its a matter of preference and how you use and weight the boat. I'm no expert but there are several threads on here comparing props.
Users browsing this forum: No registered users and 268 guests
