It is currently Sun Mar 22, 2026 3:23 pm
 Post subject: How do I drain out oil?
PostPosted: Fri May 18, 2012 9:03 pm
Hello Guys,
I have a 2012 Axis A22 with LS3 engine (450hp). And I'm located here in the Philippines, so there's no official service center for Axis/Malibu. I'm about to change oil for the very first time, and I have an oil pump ready. But I can't find where to drain the oil first.
Can anyone here please help me where can I find and drain out the oil?
Thanks,
Philip
 Post subject: Re: How do I drain out oil?
PostPosted: Sat May 19, 2012 7:49 am
I pump it out though the dip stick tube.
PostPosted: Sun May 20, 2012 12:46 pm
I suck mine out threw drain tube. I imaging it's same affect just without the hassle of running drain house out the back
PostPosted: Sun May 20, 2012 1:20 pm
I use the pl-6000 seen here
http://www.goodboatgear.com/detail/1975 ... Extractors
You should have a tube with copper end cap attached with clip on the left side of engine when looking at it from the swim platform. Uncap, run the pela and start pumping the oil out. For the filter, I use a large plastic zip-loc bag once I get the filter loosened to prevent oil spills.
**make sure you do this after the engine has been run to warm up the oil** otherwise, you'll be there a long time with the pela pump.
