It is currently Fri Nov 20, 2026 3:04 pm
 Post subject: 2012 Axis A22 - Stereo Wiring
PostPosted: Mon Jul 15, 2024 8:00 pm
I am looking to replace the RCA cables from my Head Unit (starboard side console) to my amps (in the port side locker), as they are bad.
My boat is an hour away, so before heading up there to try to figure out how the wires are routed, I thought I would check here to see if anyone has replaced these. If so - can you give some detailed explanation of how they are routed? And if there are any panels or cushions that I need to remove when routing the wires.
This should help me when I go to do mine, and also if you have an idea of how long they need to be, this will help me order the right length. Any help is appreciated!!
Users browsing this forum: Google [Bot] and 84 guests
