It is currently Sat Aug 08, 2026 8:53 pm
 Post subject: Impeller for 2015 T22 with Monsoon 350 PCM
PostPosted: Mon Aug 10, 2020 3:18 pm
Bakes was not certain but recommended the following:
https://www.bakesonline.com/pcm-rp06102 ... e-kit.html
Can anyone confirm or suggest another part number. The manual suggested RP061018 impeller kit.
 Post subject: Re: Impeller for 2015 T22 with Monsoon 350 PCM
PostPosted: Sat Aug 15, 2020 8:38 am
I have the 2015 T22 with 350 Monsoon. I used to buy my impellers from Bakes, but lately I've been buying from Amazon.com. Mainly because of free shipping. That being said Bakes is now $6 cheaper than Amazon.
This part and gasket works perfectly. Just make sure you run down the cover screws all the way - essentially crushing the little white foam gasket. Otherwise these screws will back out.
Johnson Pump 09-812B-1 Impeller
https://www.amazon.com/gp/product/B0039 ... UTF8&psc=1
Good luck.
