It is currently Mon Oct 12, 2026 10:11 am
 Post subject: 2015 Axis t23 issues
PostPosted: Fri Jun 28, 2019 12:00 pm
Hello all,
First time post. I am having some issues with my T23. 2nd time out yesterday for the year and the surf gate will not come out or the speed control will not detect speed.
I tried recalabrating(where both gates come out and go back in and nothing)
I did mess with the perco switch. Had it on battary 2 last time out, then switched it to 1&2 yesterday.
Im not sure there is even a spin wheel on the boat? I thought it was a gps speed system. Any help would be appresiated.
 Post subject: Re: 2015 Axis t23 issues
PostPosted: Tue Jul 02, 2019 10:47 am
mattd18 wrote:
Hello all,
Go into your settings menu and enable the paddle wheel speed sensor instead of GPS (directions on how to do this are located in your manual). Try that first and see if you still have the issue.
2018 T22
PostPosted: Wed Jul 03, 2019 10:10 am
I have had issues in the past where I get a piece of sand into the paddle wheel and then the speedo will not read, therefore the gate will not extend nor the cruise work.
I usually just spin the paddle by hand and it will free up and read correctly.
