It is currently Mon Nov 02, 2026 6:18 pm
 Post subject: t22 heater core
PostPosted: Fri May 25, 2018 12:31 pm
So i got a new heater core, perfect match.... did not take a pick before taking out the old one.. does it matter which way the hoses hook up ? or a way to tell which hose is the return.
I know this is a simple process and i screwed up..
 Post subject: Re: t22 heater core
PostPosted: Fri May 25, 2018 3:36 pm
I actually just called them to verify the proper way to install their low idle wye. I asked about heat exchanger flow direction for you. Flow direction does not matter. So just hook your hoses up. It’ll work as it did before.
2016 A22
