 Post subject: 2017 T22 stereo will not pick up FM stations
PostPosted: Sun Jun 18, 2017 12:44 pm
I have a new T22. the only big problem is that is will not pick up FM stations. The stations are in a city 35 miles away. My car easily tunes all of them in. The boat only get 1 if I get the wire antenna out and hang it on the tower. If I change the antenna will it cure the problem?
 Post subject: Re: 2017 T22 stereo will not pick up FM stations
PostPosted: Sun Jun 18, 2017 1:29 pm
Fm radio? That still exists? lol..
PostPosted: Sun Jun 18, 2017 7:18 pm
Same issue with mine. I sent to dealer and he said hooked up but not sure why not getting channels. I will look into again in off season, if you figure out please do tell us.
PostPosted: Sun Jun 18, 2017 8:22 pm
Not a fan of the new stereos also for anything other than Bluetooth streaming.
PostPosted: Mon Jun 19, 2017 5:44 am
I heard it is an issue with the electrical field of the new class D WS amps. Also heard a fix is in the works.
PostPosted: Mon Aug 07, 2017 7:18 am
Malibu says it is and issue with the magnetic field form the amps. They changed my amps and said it was better....it is not. They do not seem to have much in depth technical ability at Malibu.
I don't know of any other fix in the works. They would rather ignore it.
PostPosted: Tue Aug 15, 2017 3:22 pm
Same issue and experience with me. New 2017 AXIS T23 owner with just 46hrs on her.
Sent from my SM-G900P using Tapatalk
PostPosted: Tue Aug 15, 2017 7:32 pm
Has anyone changed head unit with any luck picking up fm?
