It is currently Thu Sep 24, 2026 10:01 am
 Post subject: Clean up on wake
PostPosted: Tue May 16, 2017 7:55 pm
Pull my 7year old behind 2017 a20 starboard side wake cleans up nice but port side when adding h2o to ballast on that side will clean up some but wrecks starboard side wake, I have tried center ballast wedge up wedge down etc. FYI we pull him at 16 MPH, but have played around with faster speeds up to 22 MPH. How are you getting both sides clean?
Thx
 Post subject: Re: Clean up on wake
PostPosted: Tue May 16, 2017 8:31 pm
Do you have a plug and play bow bag under the front cushions? Also just so you know the port side tank is 242lbs and the starboard side is 208lbs for a combined 450 in the rear, the belly tank is 350lbs. Thus giving our A20s the 800lb stock ballast. I run a extra 40lb pop bag under the rear starboard side cushion to even out the tank weights. Adding some more bow weight will help clean up your slow speed wake. I run 2500lbs plus wedge in my 16 A20 and the wake is clean. Stock 800, sumo 475s rear, wakemakers 400lb P&P bow sack and 300lbs of lead wake bags on top of bow cushions.
PostPosted: Tue May 16, 2017 8:35 pm
I pull my 7 year old with no wedge, no ballast at 18.5 at 55' and the wake is clean. We have an A22, same hull as an A20
2017 A22
2000 Sunsetter Lxi
PostPosted: Wed May 17, 2017 6:40 am
tough situation. you need as little weight as possible in the boat. that's hard when you have a bunch of people and gear.
drain all ballast completely empty and try moving people to the front instead of the back.
PostPosted: Wed May 17, 2017 1:17 pm
So in general I need weight at bow?
PostPosted: Wed May 17, 2017 2:58 pm
Yes axis loves bow weight
PostPosted: Fri May 19, 2017 5:31 pm
I've been pulling my son since he was 3 (he is 8 now) behind an a22. The previous hull was super easy to clean up and you could get down to around 16 mph with a clean wake on both sides by doing nothing. The newer hull is better for surfing but a little more sensitive side to side. The best wake board set up for kids with the 2015 and newer hull is 18mph, no weight except in the bow and get 2 50lb bags of lead https://www.leadwake.com/. I move the lead around the cabin depending on who is in the boat and where they are sitting.
PostPosted: Sat May 20, 2017 4:14 am
Thx Elc I will give it a shot this weekend. Thx all for advice
PostPosted: Sun May 21, 2017 7:55 pm
Ordered bow sac today will update after install if anyone is interested
PostPosted: Sun May 21, 2017 8:12 pm
Which sac did u end up getting?
