It is currently Sat Oct 31, 2026 1:12 pm
 Post subject: Belt squeal
PostPosted: Sun Aug 07, 2016 12:07 pm
Hi. I have a 14 t22 with the 330 motor. Just wondering if anyone else has a problem with the belt on the engine squealing. I've had the belt replaced and the squeal goes away for a few days then comes back. Dealer told me first belt was wrecked because of excess water in the bilge. I know this is not the case as I have never had more than an inch or two of water in the bottom of the boat at the mid drain. I'm getting sick of being the newer boat at the launch and fire it up and it squeals for a few mins.
14 t22 with sg
 Post subject: Re: Belt squeal
PostPosted: Sun Aug 07, 2016 12:15 pm
Have you tried any belt conditioner? I usually spray mine beginning and end of the season. Helps retain belt life and I've done it on previous boats and vehicles and never had any squeaks/squeals.
Other issue may be misalignment of the pulleys. That's the only thing I've seen cause them to squeal other than a really old or wet belt.
Hope this helps but I know it's like a shot in the dark.
PostPosted: Sun Aug 07, 2016 12:31 pm
Belt alignment is good. Brand new belt this year worked good for the first 5 hours of use then it squeals every morning when I fire it up. I'm pretty sure it's a moisture problem just trying to find out if anyone else has this problem.
14 t22 with sg
PostPosted: Mon Aug 08, 2016 12:54 pm
My 2014 a22 has squealed before. But it was due to water in the bilge. Good luck and keep us posted.
Users browsing this forum: Google Adsense [Bot] and 56 guests
