 Post subject: 750s or 900 in 2015 A22
PostPosted: Fri Jul 29, 2016 8:05 pm
I need to order bags for my a22. Do the 900s fill all the way? Or do they bunch up. I'm trying to decide between 750s and 900,s any input would be great.
 Post subject: Re: 750s or 900 in 2015 A22
PostPosted: Fri Jul 29, 2016 8:33 pm
900's more is better. Should fit fine.
PostPosted: Fri Jul 29, 2016 8:45 pm
There's still some room to spare with the 750s full in our '15 A22. 750s are more than enough for wakeboarding but when going out with a light crew you might want a little extra to dial in the surf wave. I have a couple of extra bags to use so it's not an issue.
Remember you'll want to put a few people or an extra bag up in the bow if you go that heavy in the rear.
I've seen some people mention the wakemakers bags recently that are somewhere in between (825 I think?). Could be another option to look at.
PostPosted: Thu Aug 04, 2016 8:57 am
Surfing a20 I run 850 size, straight line previously labeled 50x20x20 bag as 750, now it's an 850, I might get 650-750 fill???? So you should get 1100's for surfing, I run a mushroom 950 nose in the old style locker that fills 800??? Plus wedge, I have a nice pushy large goofy and slightly less regular. I want to go bigger with lots of people, but I need the 2419 acme(have1235 at sea level) to go even bigger cause 1235 struggles to get to 10.4 surf speed.l with 330hp. Can't wait for next year. You could run the 950 up front plus 400 lbs in seats up front to lower the nose from heavy weighting the back
PostPosted: Thu Aug 04, 2016 8:58 am
Surfing a20 I run 850 size, straight line previously labeled 50x20x20 bag as 750, now it's an 850, I might get 650-750 fill???? So you should get 1100's for surfing, I run a mushroom 950 nose in the old style locker that fills 800??? Plus wedge, I have a nice pushy large goofy and slightly less regular. I want to go bigger with lots of people, but I need the 2419 acme(have1235 at sea level) to go even bigger cause 1235 struggles to get to 10.4 surf speed.l with 330hp. Can't wait for next year. You could run the 950 up front plus 400 lbs in seats up front to lower the nose and lengthen the wave counterbalancing from heavy weighting the back
