It is currently Fri Oct 23, 2026 6:42 am
 Post subject: A24 prop recommendation
PostPosted: Wed Jun 29, 2016 10:08 am
What prop are you running in A24 with 450 motor for wakeboarding. I have the 2016 A24.
 Post subject: Re: A24 prop recommendation
PostPosted: Wed Jun 29, 2016 1:21 pm
I have the 409. I have bow PnP and stern 750 PnP. I run the 2313. I wanted a 2315 but there was a mix up when I got my prop. The difference isn't THAT great. My top speed is 38 and can plane out with all sub floor and bow all full. The 750's just over half full. And wedge deployed with ease.
PostPosted: Wed Jun 29, 2016 4:23 pm
What is your rpm at wakeboarding speed loaded?
Thanks got the info. However my set up is completely different since the transmission ratio is different on our boats. With the lower gear I shouldn't have to use that low of a prop. I am running the 2249 now and it does the job but seems like it could be better on hole shot.
