 Post subject: Center Ballast
PostPosted: Mon Jun 27, 2016 9:35 pm
Where would I find the clamps for the center ballast? I think it may be leaking as I'm getting water in my bilge and I'm not taking on any water. Today the bilge had to be on for a couple of minutes to remove the water. I have checked the clamps on the front and rear ballast.
2014 A24 w/ LS3
 Post subject: Re: Center Ballast
PostPosted: Tue Jun 28, 2016 10:17 am
On my A22 it is easiest to access through the floor but you can see it through the circular hole where you put the center plug in. Another place I had a leak was on the connector to the through hole for the front and center tanks.
Good luck!
