It is currently Sat Jul 11, 2026 5:15 am
[ 10 posts ] |
gadwa1
Post subject: Wake Tower Posted: Thu May 05, 2016 5:07 am |
Hi guys I have an older A20 and my new shed is a fraction low, has any one tried to have a slightly shorter sides to hold the tower made up, I only want to shorten it an inch or two ? Was going to see if a metal fab place could make two new wake tower sides a fraction smaller? thoughts
Cheers Mike
paula.shane
Post subject: Re: Wake Tower Posted: Thu May 05, 2016 5:48 am |
Joined: Wed May 02, 2012 4:25 am Posts: 84 Location: Adelaide Australia
Could you not just trim off what you need off to lower it and re drill the through holes?
2012 Axis A20
_________________ 2012 Axis A20 Down Under
r33pwrd
Post subject: Re: Wake Tower Posted: Thu May 05, 2016 6:43 am |
Joined: Sat Jun 06, 2015 10:35 pm Posts: 1181 Location: Sammamish WA
Personally I think it would be easier to raise the sheds door opening an inch or two.
_________________ -2015 A24 - 409 HP - 2249 Prop - 1100 rear sacs - 950 front sac - 290lb rider with Red Rocket and Phase 5 Quest
onwi
Post subject: Re: Wake Tower Posted: Thu May 05, 2016 7:54 am |
Joined: Thu Apr 11, 2013 6:19 pm Posts: 199 Location: SE Wisconsin
Is your trailer as low as possible?
_________________ ________ 2012 A20
vanamp
Post subject: Re: Wake Tower Posted: Thu May 05, 2016 8:32 am |
How much to tall is it exactly? If it really is fractions then let a little air out of the tires and experiment with different hitch heights.
admin
Post subject: Re: Wake Tower Posted: Thu May 05, 2016 1:57 pm |
| Site Admin |
I have heard of the tire trick. Let the air out and squeeze it under.
I have also heard of guys digging out the gravel for clearance. If your shed is on a gravel floor you might be able to dig down enough to clear.
dustinjean
Post subject: Re: Wake Tower Posted: Thu May 05, 2016 7:17 pm |
Joined: Wed Sep 03, 2014 5:19 am Posts: 457 Location: Mt. Washington, KY
I personally wouldn't go modifying the tower itself. I had to remove the good looking fonished front on my boat shed I buily when I upgraded boats to gain a few inches but you can also adjust the axle height on the trailer
_________________ 2014 A24
gadwa1
Post subject: Re: Wake Tower Posted: Sat May 07, 2016 4:07 am |
Thanks guys but it may be as much as few inches, local regs say the shed can only be 3mtrs then there is the roller door putting it at 2.8, thought about leaving a grove on the cement for the tyres but its just not enough, with the shed and floor and driveway we are at almost 20k, Thanks any way
Mike
r33pwrd
Post subject: Re: Wake Tower Posted: Sat May 07, 2016 5:14 pm |
Just lower the trailer like said above..
AJWest
Post subject: Re: Wake Tower Posted: Sat May 07, 2016 9:34 pm |
Modify the trailer by maybe adjusting the torsion arm on the splines of the axle to bring it down a bit. Lower profile tires maybe?
[ 10 posts ] |
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 29 guests |
